Technical Auxilliary Electrics
al_scott
Nr Telford
I want to wire in a cigarette lighter into the boot of my Weekend so that I can plug in an electric coolbox.
Anyone know the best place to get a feed from?
*** 1998 Marea 2.4 TD Weekend HLX ***
The front cigar lighter feed comes from a 30A fuse and should be OK to use if you put in an 'inline' fuse for the coolbox.
If you don't have climate control there should also be a spare 30A fuse, (or space to put one).
I've got climate control.
So what you're saying is that I'm best to run a feed from the cigar lighter connection in the fuse box in the front.
Right, I've got hold of some 30A wire. I've also bought a little device which will stop my battery getting flattened.
http://www.maplin.co.uk/products/module.asp?CartID=040711075634882&moduleno=37773
Anyone suggest the best/easiest route for me to get the wire from the boot to the fuse box?
Cheers, Al
