Aux drive belt change on JTD / anybody with a porter manual
R
Rob W
Hope somebody can help.
I've got a Marea Weekend 105 JTD (1999) and it's got this small problem with the auxilary drive belt.
I had it replaced Feburary when the cam belt was done as it was starting to squeal a little at higher revs. Problem sorted for a while. Then the squeal returned and after a couple of months the belt "jumped" a notch on the pully wheels and merrily shreaded on the two journeys I had to make before I could give it back to the garage. They changed it and the drive pully in which the rubber had gone supposedly causing the problems.
Well "hear" I am again with a squeeling drive belt and I'm loathed to take it back to the garage for another massive bill so was planning to change this one myself and have a good poke about at all of the pully wheels while I was at it. For those intereseted it squeals afer a mile or so when it as warmed up a little and then constantly at anything above 1500 rpm. Also nasty rubber smell in the car when stationary.
Anyway I was wondering if anybody had a servicing manual that includes the JTD and could look and see if it had useful information for changing the drive belt before I went and bought one (I know that I will probably need one eventually but there is not point getting one if the information is not good for this job).
Many thanks
Rob W
The belt change is identical to the 1.8 petrol engine. Sounds to me like you have a tensioner or idler bearing partially seizing as it warms up. I took mine in to get done, and after jacking the car up and removing the wheeel, it took him about 6 minutes to change the belt. I think the hardest part is removing and refitting the wheel arch liner to get at the belt!
After reading your post again, if the idler or tensioner pulley is suspect, it's the outside of the belt that will have the damage.
1
660
Dark Lurker
C
7K
ChrisKnottIns
C
B
558
BravoMad
B
F
7K
F1-ANG
F
