Technical Automatic transmission refill Fiat Pop
ernieb1986
portsmouth, va
Hello, I changed out the tone wheel because the car was in limp mode. While removing the transmission it said to drain the transmission fluid, so I did that. I also disconnected the coolant lines in the front of the transmission so I don’t have an accurate reading on how much transmission fluid came out because it all went in the same pan coolant/transmission fluid. I drained the fluid from the transmission drain plug 17 mm hex head. Does anyone know how much I need to add? I keep getting multiple answers.
Hi, 🙂
We didn't get that gearbox option in Europe (we had a semi-auto, and smaller motor, for emissions)
Look on the sidebar of this forum
Links to;
Owners manual
EPER - Parts system
eLEARN - serving information
Obviously focusing on the Mexico built 500 sold in the America's 🙂
EDIT:
some figures will be quoted as a Service refill / Rebuild total fill
Obviously you want the lower figure
Is there still a "dipstick", as was traditional with any automatic?
(my last was with a Ford Pinto... so VERY old tech)
