Hi, I just joined this forum and would like to see if there is someone out there who can help me with my automatic transmission problem. I am having the year 2000 Ulysse 2.0 Petrol version with 16v tip-tronic transmission model. During cold morning start ups, my trusty ulysse would auto switch and stuck at 3rd gear and the gear display indicator on the instru panel will flash. This is regardless of how fast i am going. The only way to "correct" this was to "off" the engine and re-start. I had this same problem 3 years ago and was "solved" after I sent it to a Fiat mechanic and detected a faulty leaking sensor. So i thought this problem was due to low fluid level. But recently, it happen again and this time there is no leak and the problem persist even after i change the 4 litres of fluid. Can someone help? I am in Malaysia.
