SpeedFreak001
Hi everyone I need some help please? I installed a JVC KD-G355 in my 1997 FIAT UNO FIRE 3 dore 1100. I did the installation as follows:
I disconnected my battery terminals. Then I took my ground cable on the back of my radio and connected it to the negative terminal of my battery. Then on my radio I have got a yellow wire called my memory cable and I connected this cable to my positive pole on my cars battery. Then I looked for a A/C on my cars ignition but didn't find one so I then tested all my cables coming from my ignition there was a orange , yellow & red , thick grown , thick red and a blue & yellow one so I decided to connect my power cable (the red cable on my radio) to the blue cable on my ignition.
I have got a ICE 435 4 channel Amp with a 800W Earthquake sub and 2 6x9 280W LG speakers in the back. I connected my 3 cables from my Amp as follows:
There is a thin oranje cable that I connected with normal 2.5mm cable to the remote output only cable (blue & white cable) at the back of my radio. Then I connected my Thick black cable to my ground cable of my radio that is connected to my negative terminal on my cars battery. Then I connected my thick red cable from my Amp to the positive terminal of my battery. I connected and extended both my thick black and thick red (positive & negative) cables at the back of my amp with 4mm cable that I think is to small because if I play my radio harder than 22 on the volume one of my fuses on my amps cable burns out I use 10 - 15 fuses. Can anyone please give me there opinion to better this installation because my battery has gone because something keeps draining it so I disconnected my radio and amp and now it seems the problem is gone. The terminals on my battery made sparks when removing one of the terminals and when I disconnected the radio it doesn't make the sparks anymore and the battery doesn't get drained at all please can anyone help please.
And is there any way to make a A/C for a FIAT UNO because its the first time that I have seen a car without a A/C
Thanks for the great form it helps allot
