Anyone with wolfrace wheels - Help !
G
Gav
I'm probably going to sound a bit thick here (nowt new there comes the shout !) but I've just taken delivery of my new wolfrace wheels and I cant get the centre cap of that covers the bolts. :(
It has a little cut out that looks like it is to put something in to prise the cap off but when i try it just seems to flex from the middle as if there's something else holding it in.
Is this the case or am I just prising like a girl and need to give it some more oomph ?
Gav
You don't need pants for the victory dance
Can you take a pic?
If its right on the edge of the center cap, it probably prises off, but if its nearer the centre its probably something else.
Daz
what wolfrace are they mate? as u may have to screw the centre cap to take it off, usually theres little allen key holes, have a look for allen key holes mate
matty
just been speakin to a mate of mine and he sed that the whole disk (hexagon whatever) spins anti clockwise, DO NOT PRISE IT OFF, actually press ya hand on the whole peice and turn it it should eventually spin off, he could be wrong, but its worth a try init
matty
RE:
Right, I've just tried unscrewing them but still no luck !
GGRRRRRRR, I want to fit em !
Any other ideas anyone ?
Re: RE:
I had this prob, did you not get a little instrument with the wheels, the end of which is similar to the hole at the edge of the centre covers. You just hook the lip under and basically prise ot off, the clips will just be a bit stiff, ill try and get a piccy of the instrument
Hope this helps
Stu
Re: RE:
You may be able to make out the little gap
Put the tool in there!
Stu
C
7K
ChrisKnottIns
C
2
880
Dark Lurker
3
465
Tim R
T
