General  anybody help me
nemo
sunderland, United Kingdom.
i just get a panda 750 (92 reg), and the engine cover leaks oil. it sounds like a old motocycle. is it fine? but somebody tell me that is the gasket of exhaust broken. but the sound is comes from the some where of the engine. thanks!
It will only take you 30 minutes and thats being on the long side. Remove airfilter box and the rocker top is only four bolts.Remove, fit new gasket bit of goo espically in corners and rebuild. Job done.
I think it's better not to use any sealant...only clean very well both the surfaces(make them reflecting as a mirror:D) and then screw the bolts when you replace the gasket and after 1000km...;)
