I actually have created the psshhhht sound as a byproduct of a mod I did to my Doblo T-Jet: installing a modified Bravo intake pipe with a K&N pod filter on it.
When I do a medium to full throttle acceleration (which also makes you hear the turbo spool up) and let off the throttle at around 4k rpm, the factory recirculation valve blowing off is very audible through the K&N filter.
Since you have a Bravo, all you need to do is remove the factory airbox and just keep the 1 piece of pipe that is connected to the turbo and also has the lines from the recirc valve, PCV, evap and boostregulator connected to it.
On the end where the rest of the factory intake system was, you fit a good quality pod filter.
I used a K&N rg-1001rd, which is a direct fit on the stock pipe, but you should check for clearance in the Bravo engine bay. Also don't forget to provide some support, preferably mounted to the engine so everything moves as 1.
Here's how it looks under the bonnet of my Doblo. You can see the pipe I mean, but yours will have a ribbed semi-flexible bit in it I had to cut out to make it fit my Doblo. If you look very closely you can see a bit of black metal supporting the pipe mounted to the engine mount.
https://www.fiatforum.com/members-motors/437147-candisas-doblo-t-jet-lpg.html?p=4248384
Alternatively, and for almost zero money, you can just remove the bit of hose between the recirc valve and the pipe integrated into the engine cover, put a stop on the pipe in the engine cover (so the engine doesn't suck in warm and dirty air that way) and hoseclamp a bit of mesh (to prevent dirt falling it but allowing air out) to the recirc valve.
This way you also hear the pssshht, but no turbo-spool and no other advantages of a pod filter.
