Technical Any tips for fitting a new rear hub?
symonh2000
Oxfordshire
Especially after what happed to Sammiboo..
I have a new hub and wheel bearing assembly to go on the rear drivers side of my coupe, and would appreciate some hints and tips on fitting, as well as anyhting I should not do when I put it on.
Thanks,
Simon.
I didn't take the risk, and paid a professional to fit it for me (although Sammi did the same :eek: ) I trust that sort of work to a reputable garage.
Have you just signed up to fccuk to ask the question?!
I have signed up to Fccuk, and when I asked the question it seems that it is an easy job, and not much can go wrong.... Apparently it just unbolts and the other slides on. In theory at least. I am pretty sure I can take more time to fit it that a professional also, as I have not got to fit several cars in to be fixed, like I would if I was a garage.
I have fitted the new hub, it took about 2 hours. It does not look like a very substantial item though I was suprised at how it manages to hold eveything... Fitting was pretty straightforward though.
pinin__prestatyn said:
Furry muff :)
My level of competence with a spanner leaves a lot to be desired. I was chuffed at fitting a bumper myself this weekend!!
wow, and i thought i was mechanically incompetent the other week by jacking my car up and fitting a de cat pipe which took me 2 hours and a lot of sweat!! i thought that was a easy job, but i think that fitting a bumper takes the biscuit!!! :D
From what I know you need the bearing assembly pressing into the hub. You are best getting that done at a reputable garage.
To fit the hub to the suspension arm you will need a blooming big socket and torque wrench. If you don't have a torque wrench I believe there is a setting on standard 3/4 drive ratchets called F'ing tight.
Only changed the drive shafts on the front of a Tipo 16v and removed the rear hub on a disc-spec Tempra.
can i just point out, the bearing that was replaced by someone on this forum was fine, the one i had replaced by an italian car specialist was the one that failed, it failed a few weeks after it was fitted. Just something to keep in mind.
you get the new hub and bearing as 1 bit,
just use a new nut, dont forget to replace the washer, easy job realy, make sure that you have a torque wrench that goes up to the setting needed to re fit
The rear hub comes as an entire assembly on the Coupe. The bearing isn't available seperately.
H
no surprises there, who was the "specialist"?
sammiboo said:
Sorry cant name them. I am still going through proceedings
Sammi, would you PM me "hinting" who it might be please, I promise I will not reveal who it is to anyone. I'm having some pretty serious work done to my coop in a couple of months and I want to take her to a decent specialist.
