Technical Any idea what is causing these error codes?
My Ducato camper van went in for its annual service and MoT last week. On the way there, the airbag light came on. The garage ran their scanner and it came up with codes they don't recognize. I'm wondering if anybody on here recognizes what these might be caused by?
Airbag B00D514
Body Computer U170587 and B10AA4A
The B00D5-14 refers to the airbag control unit connection to the passenger disable indicator.
There is either a short to ground or open circuit in the wiring between the airbag control unit and the instrument panel.
As jackwhoo has already pointed out, the other two codes refer to a canbus error message or wiring /connector issue between the radio and body computer - probably because of your fitting of the Sony head unit. Is your odometer flashing? If so, then you can likely fix that and the two related fault codes with a proxy alignment.
If there is a passenger air bag exclusion switch try toggling it off / on a few times and see if exclusion light on dash behaves correctly
