General antenna panda
cirsty
Netherlands.
I have bought an antenna for mounting on the hinge.
I have troubles on putting it on the hinge, who has experience or has mounting instructions and how do you lead the cable inside the car.;)
As far as I can remember...
The plastic hinge cover is unclipped (with a bit of difficulty).
The aerial base is the same shape as the cover you've unclipped, and clips on just the same as the piece you took off.
On the last one I swapped over, the lead was just run through the gap near the hinge when the door is open, and there's enough "give" in the door seal rubber to accept the thin lead which is routed along the "parcel shelf" to the back of the radio.
There may well be a more clever way of getting the cable into the car via the hole where the hinge bolts are, but I can't say I've done that in living memory:I The books I've got give no clues (although Porter usefully suggests leaving the old cable in, and re-taping the ends together if you replace an aerial, which I suppose means there is a cunning and difficult route for them, when done "properly")
HTH
Regards
John H
I would remove the aerial mast when you leave the car, as it is not available separately :(
My local low-life love breaking aerials off cars [:(!]
Steve - [the barking
is having a rest]
Oh Lord, won't you buy me a Fiat Panda! (with apologies to the Queen of the Blues)
You've not tried Fiat then? When I bought mine it was about £7-ish in approx 1995 ...
Steve the geriatric Panda and Beagle freak
G781 TUT: White Panda 1000CL - 31-08-1989 to 09-03-2004 (may she rest in pieces :()
J154 FMX: Red Panda 750L in good condition - waiting for me to rescue it :)
Currently cycling 16 miles a day to work and back :)
