Soupaman86
- Joined
- Apr 15, 2013
- Messages
- 8
- Points
- 1
Hi, I'm new here, registered after browsing these forums as a guest for a long time.
I've returned to petrols, now the owner of a MK1 Punto 60 S, having had faster and more refined cars in the past, I know that the Punto will never be a Subaru, but I'd like to add a turbo, and could do with a little input on a few things if that's O.K.
Things I've done so far:
Lowered 40mm all round with a front strut brace.
Changed the rear trailing arms.
Water pump, tensioner, and belts.
Mist jets, and de-wipered rear.
866 cam and the head with bigger valves.
Brakes will be uprated in due coarse.
I've got to changed the flywheel as the ring gear's damaged, (starter too) as well as change the clutch due to oil contamination, and overhaul the gear box as the input shaft bearing is making a noise, but then I plan on going down the turbo route, but I'm a little unsure on the spec I should be aiming for, I'd be happy with something in the region of 90-100 bhp, my plans are:
Standard manifold with a turbo flange welded on, to this I'll bolt a GT 15, taking my oil feed from near the filter, and a return pipe to the sump. I'll have a front mount intercooler, and I'll vent to atmosphere with a B.O.V.
Pistons from a 16v 1.2 Punto instead of decompression plate, perhaps an MLS gasket and a lower rated thermostat.
Fuelling will be MF2 Aquamist as Megasquirt is beyond me and anyone that I currently know.
Would increase fuel pressure if needed.
Custom exhaust down pipe with sport catalyst, with a free flowing Sportex in the end.
Here's where I'm stuck, inlet manifold. Had assumed that I could use the Punto 75 inlet manifold and control the four injectors for boost with the Aquamist, and retain the SPI for off boost, but I believe the 75 inlet won't bolt on, have also read that some state problems can arise as it's a dry manifold.
is there anything off the other similar engines that are MPI that I can use, as I'd rather have four injectors for boost, so that I don't have any issues with a cylinder being lean, as I've read this can happen, or am I being O.T.T?
What sort of boost would I be looking at with my theoretical spec?
One other question, regarding MOT time, if I was to lower boost as well as fuelling, would that have a negative effect on the emissions, or would it be the opposite if I had the fuelling dialled as well as the boost, would emissions be cleaner?
Sorry for the long post,
Regards, Callum
Regards, Callum
