Hello!
I have some problem with the charging. The batteri lamp is never on, not even when you have the key half way. It seems like th alternator is not working properly. I put an Voltmeter over the battery and it shows 12.15 Volt. When I start the engine it drops to 11.7 Volt, isn't it suppose to rise to 13,7 Volt or something if the alternator is working? Do I messure at the wrong way?
I went to 2 garages and they both said the alternator was broken, now when I changed the alternator it is still the same... so nothing wrong with the alternator. I found a page on internet describing my problem with the lamp. The problem could be solved in 3 ways
1) Change the alternator. Done!
2) Check earth between alternator and chassi.
3) Change the charging regulator
How do I check if the alternator is grounded? I have 3 wires from the alternator, one red, one brown and one to the instrument panel. If I loook at Haynes electic schedule it is a earth symbol on the alternator. Is this another cable, that I don't have? Or is the fact that the alternator is joined with the car earth enough?
Where is the charging regulator? There 3 different kinds showed in the pictures below...
Ahh I found it, (I think), it is attached to the alternator, so when I changed the alternator I changed the regulator too. Hmm now It is only the earth left to check... how?
