Hi all, our 2006 2.8 had the battery light come on and voltage at the battery was only measuring 11.8. The alternator looked original so I changed it to a new one. The alternator is still not putting out any voltage(there is battery voltage present at the alternator, currently 12.3). I checked the exciter wire and it does not appear to have any voltage going to it as well, I see this should be either around 0.7v or 12v...can't seem to get a clear answer. Anyone here ever had the same issue? I have battery voltage going to the alternator, so I know the mega fuse is fine, the battery light on the dash comes on, the van will start if the battery has enough voltage. Is there a fuse, or connector, or can anyone tell me where this wire goes so I can trace it without removing a whole bunch of stuff I don't need to?
This all happened while the brother in law was borrowing the van, which is still at his house an hour away, so having a plan before heading back over would be my preference.
Cheers, and thanks in advance!
