General  alloy wheels
alsithy48
wigan lancashire
hi there, ive just bought some fiat panda alloy wheels for my fiat doblo, what I want to know is first can I use the steel wheel studs from my doblo or will I have to buy some alloy studs and will the alloy stud for a doblo fit the alloy panda wheels, my doblo is a 2004 1.3 diesel multijet 7 seater hope someone can help me.
kind regards,
alsithy48
Not 100% but if studs they should be the same, if bolts they are probably specific for alloy fitment and nuts would also be alloy specific nuts..... they often have a conical washer attached which helps to seat the bolt or nut without damaging the alloy
Check at breakers yard to see which bolts,,nuts are used if its the sort I am on about you will see what I mean
