any lights on the dash are MOT failures...
as far as i am aware it is a mot failure now, unless you change the steering wheel to say a momo item with no airbag in which case it is a advisory i am led to believe.
only airbag lights... MIL is a pass
I believe that the car has to have the airbag fitted if it origionally came from factory with one, so again this would be a fail.
Only for a little while longer, MIL will then fail I think (although your a tester aren't you Richy).
Information lamps won't fail being on though (typically not red).
im not a tester MEP but cant see how an illuminated MIL would be a fail. its an info lamp telling you that something is wrong. it doesnt mean that the car is unsafe or has emissions problems.
I think it's because, although like you say it's not only a warning about emotions system failure, they assume most causes of MIL illumination is emissions based![]()
