Hi again,
2007 3.0 X250 here.
I recently replaced the passenger bench with a single seat. I put a 2 ohm resistor in place of the third seatbelt pre-tensioner to keep the airbag module happy. This worked and case closed... Today I was driving and suddenly the airbag light lit up. I assumed something wrong with the resistor so I checked that first but nothing wrong there. I then connected the original 2 pretensioners that I took of the bench. Still nothing. So I connected the pretensioner on the new passenger seat to the driver one, to rule out an issue there. Still got the light.
So I'm afraid I should look somewhere else... But the car doesn't give any codes, at least not with the generic scanning app I'm using. Multiecuscan isn't an option because it's a Citroen and I could only connect to the ECU in the past. Any clues?
2007 3.0 X250 here.
- Model
- X250 3.0
- Year
- 2007
