Technical Airbag warning light?
lowaaa
Hi, Fiat punto mk2 1.2 8v.
I've got an air bag warning light on, been on for two days now.
Tried to read the codes with an OBDII scanner but it shows there aren't any error codes?
Anyone got a clue on what I should do?
Thanks.
(these two symbols).
Basic obd2 code readers can only connect to the engine ecu.
You need a code reader capable of reading air bag codes from your car.
M E S should be able to read air bag codes.
In meantime check the wire connectors under the front seats are fully connected.
And if you have a switch to disable the front passenger air bag for when child seat fitted make sure it hasn't been knocked/switched.
Thanks.
Pretty sure the Orange symbol is passenger airbag -as Jack says :)
I broke the plug on my switch for passenger isolation..
That put on both warnings you have :eek:
It was a 169 panda.. but identical switch
I used a 188 punto switch as a replacement
But needed to buy MultiECUScan to clear the errors
