General Airbag warning light.
brianpth
I had to disconnect the battery to replace the offside dipped headlight. Ever since I have had the Airbag warning light flashing. Anyone any idea how to fix.
Interesting, have te sam problem here caused by the same thing.After changing bulb, airbag warning light is on.Went to a local Fiat garage, they said faulthy airbag ecu, need to replace it.Before the bulb change everything worked just fine.If anyone knows how to fix this isue please tell us!!
Here in Greece we have a problem with the blow of the driver seat.
The best you have to do is to cut and associations cables directly without blows and solve the problem yourself.
