Technical Airbag warning light MK2 punto
whereabouts are you located, maybe someone else on here near you that has the leads and ecuscan could do a reset for you
Thanks.. that would be so great! I am based in Cockfosters North London.
Please also see a pic of the cables I got attached.. that I never managed to get working!
blue cable - set to airbag position plug that to car and other end to laptop, no need to to involve red cable
How do you set it to airbag position? Anyway I am about to try it now with just the blue cable. re-downloading multieuscan 3.2.
Will keep you posted!
It worked!
So I downloaded multiecuscan 3.2.
Opened the software.
Plugged in the blue vag cable which was set to port 3 aka airbag to my laptop and the slot under the steering wheel
Selected Connect in the software
and then in the navigation panel select errors
Then it will list all the issues which you can then choose to clear.
My airbag warning light is now gone.
So I will pass my MOT for now.
Can anyone help me understand what my faults are about? What I need to do to fix it properly?
Please find them attached as images
not yet, does anyone know where I can find the driver airbag connectors so I can give them a clean?
After cleaning the error in ecu of the airbag ,when the times comes the airbag will deploy ??
Theoretically yes.
But the airbag system send power to an element which heats rapidly and that heat triggers a chemical reaction in the airbag The Gas forming component of an Airbag, is the chemical Sodium Azide which is highly soluable in water, which means over time and with exposure to moisture it can degrade, meaning after years while the airbag might deploy it might not deploy as fiercely as it once would have, or it might fizzly and not deploy at all even if all the electrics are working.
In theory they have shown that airbags over 20 years old still work ok, however it really depends on the life the car has lead.
I have the same problem with the guy that started this topic ,I ordered VAG cable ,and I will try to erase the error but without changing Airbag ecu
I got my cable Vag ,I reset the errors on airbag and it worked ,please check the errors ,it’s something crucial ??
