With some help a proxi alignment has been completed on the new airbag mod.
The
MES (ECU scan) says all is aligned and no faults
No communication to BCM? : still an issue:
Air bag lights on, seat belt light on, fuel cut off and stop / start unavailable still showing on dash.:bang:
Please help!! any ideas welcome.
To add to this guys here's what i found when connecting up
MES:
1. Intermittant FIS Switch Fault error (Fuel Cut Off Problem) - Car starts and runs fine though.
2. Initial Low Voltage problem - cleared after fitting fully charged battery, but dash still says Stop/Start unavailable on every start up.
3. Proxi Alignment carried out and no faults recorded from this, completed successfully.
4.
MES shows Airbag Module is receiving power but also says Not Activated in lists.
5. Was showing a BCM intermittant error and some times a CAN-Line error.
I'm thinking the Airbag Ecu is probably ok and the fault might be down to the BCM trying to talk to it.
The error messages on dash when starting up only say the following:
Stop/Start unavailable (even with fully charged battery fitted).
Fuel Cut Off unavailable (car starts and runs fine everytime).
Lights on dash are as follows:
Seatbelt Light.
Drivers Airbag Light.
Passenger Airbag Light.
Yellow Exclamation Triangle.
Seatbelt light doesn't go out even when seatbelts are plugged in.
I've loaned my 4.5 version of
MES to
neil357 so hopefully he can use it to sort it out when we find the answer to his problem.
Now over to you guys...
