jaakkoilkka
- Joined
- Feb 6, 2012
- Messages
- 11
- Points
- 2
I have had, for couple of weeks, a warning in my Stilo, "AIRBAG FAILURE - STOP ENGINE". After reading some of the threads here, i sprayed some CRC in the orange connectors over right rear wheel and under passenger seat... and also to the connectors on the opposite side, which were, for some reason, not mentioned. No effect. I borrowed an OBD reader from a friend, it found only one code, which was fuel level sensor fault, which appeared few months ago. No code for register light bulb, which i changed only one week ago (not too easy, since italian engineers in their great wisdom had used tiny phillips screws in a place where rust is most likely to appear) , and no code for this airbad fault???? -I wonder why it screams for register light, but keeps quiet about headlight...-Last weekend i drove Her Hiness indoors while washing Her, and in that process She warmed herself over +10 degrees, so winter conditions should not be a problem. Is there any other chance than professional help?
