Tuning  Air induction best location
vkorras
Air induction best location ??
Hi!
I was looking on FB page bravo enthusiasts,bravo tuning perfomance etc. , about replacing the standard air induction with a cone filter!
Where (in your opinion) is better to put it??
If i put it as close as possible to the turbine,inside the engine comoartment,then it will get warm air,which is not good,right??
If i put it where the old air filter is,then it will collect water/dust/debris,because its too low...correct??
I was thinking to put it in a location where it gets cold air,but at the same time,not getting water spashes/mud/dust etc..
Any ideas??
Re: Air induction best location ??
Hi!
Any ideas??
Check out what I made up, simple but effective, I have since taken the pipe red off as it was getting wet so needs a sock over it ideally and just have the ramair filter. I had mine remapped with the open air filter but I put a bmc filter in the standard air box and the power was very restricted so I had to go back to the ramair filter again.
https://www.fiatforum.com/members-motors/356056-maserati-blue-150-t-jet-4.html
