Technical air filter for tipo 1.6 dohc
here`s a pic. of the engine :)
yep
from the looks of things you should be able to fit one in the wing, near where the plastic cover currently takes its air from. though it depends upon what sort of fitting it has underneath the plastic. it may be limited space though for clearence.
as you're pretty aware this engine is pretty rare so you're probably one of the only people on here with one.
Why would you fit a cone airfilter?
It will suck in hot air and reduce HP this way, and it will make a lot of noise too......!!!!
because the air filter will be isolated from the hot air and it will increase the power :)
it is injection and the exhaust is motech... there is no midle
chamber... and im not gaining 2-3 hp ... if you can`t answer my questinon don`t write pointeles posts...
He's not the only one with DOHC here... I have one too... Try the existing path for the filter, try stucikng it in the wing, above the gasoline vapour exhaust something.
