Technical Air Conditioning problem
mlmmike
Melbourne
New user here, just joined. OK I bought a Fiat Motorhome with a "ROLLERTEAM" build. 2015 Ducato 2.3 turbo engine. The problem I have is with the air conditioner. It was regassed, just last week. Had next to no gas, but no leaks detected. The issue is when it works, it is fantastic. so cold... But the light on the air condintioner keeps flashing. Not consistant... It is more like the switch could be intermittent like sometimes 10 times per second. . For a start, I could not figure out how to remove the switch to inspect. Secondly I wonderered if this could be related to some searches I did, where I just need to remove the resistor and put in the freezer for a few hours so it resets ? When the air conditioner works, it is brilliant, even worked the oter day all day, then next day, flashing all day... and clearly the compressor was not running as cabin was hot. Ant ideas... ? Thanks in advance. Michael.
