Good day everyone!
First of all: Please notice that English isn't my mother tongue but I will try my best to be as explicit and detailed as possible.
The car I refer to: Fiat Punto MK2, 2002 60 hp, 1.2l engine
I have a problem with my air conditioner. After the winter I noticed that it won't cool down the air anymore, so I went to my garage to refill the air conditioner. (1 1/2 monts ago).The guy working there told me that nothing of the cooling liquid was left.
He refilled it, checked if there is some leak somewhere (the machine testing this said there isn't any) and he put a special illuminant in it too see a leakage in the future.
Okay, after the refill the airconditioner worked so far, not THAT cold as I expected it to be, but it was definitely okay. I noticed a noise after pressing the air conditioner button, which sounded like darth vader inhaled a deep breath (sorry, I can't explain it better:yum
. After that sound the compressor started working and it got cool.
Now the problems start: One mont later I noticed a constant noise while having the air conditioner running. It got louder and louder and the air got cooler and cooler. A friend of mine said that the compressor doesn't run all the time, it starts and stops automatically but never runs the whole time. After noticing the noise it also noticed that the compressor ran all the time without any stop. I said okay, let it be then.
For you to have an example of that loud noise, please watch this video I uploaded for this thread:
youtube . com/ watch?v=YoaNAlyb77w
(please remove the spaces in between)
You hear that metallic noise? That's what I am talking about. It's really loud when the car is idling, it softens at around 2000-3000rpm. That's where it worked.
Yesterday I was driving and noticing there is no cooling anymore. Nothing. Again with this noise and knowing that the compressor is working.
I looked under the hood seeing the compressor running and the cooling fan working. I touched the metal pipes going to and away from the compressor. The one which is supposed to be cold (the lower one) was neutral and the one which is supposed to be hot was MEGA hot (upper one). I mean even hotter than when the whole system was working properly.
(see the compressor running?)
I really have no clue why the system is working but the cooling stopeed. When I was refilling the system the compressor didn't do a thing. And now it's running like hell, heating itself up but no cooling at all.
It was suggested to me that it could be the condenser ot the expansion valve which is located between the engine room and the inside room (the connection between inside and outside).
What do you guys suggest? Have you ever had such a problem?
I hope we can find a solution together!
Thank you for your time and trying to help!
Greetings
Brumm0815
Greetings
Brumm0815
