Hi
Hope someone can help.....
The Air Con hasn't worked properly since I bought the car so didn't use it for a long time but last year I had it re-gassed at kwik Fit, they said there was no leak on it and it did work for the journey home! But it didnt work again so i took it back and he said it was empty and filled it again and again no leak was found. It worked for the journey home again.
The next day after a long journey leaving the air con running in the hope that it would cool the car the fan stuck in the "on" position and would only switch off by removing the fuse so I had to have the control unit replaced but still no air con so assuming it is empty again. The kwik Fit guy said if it emptied again there must be a problem that needed fixing.
Assuming that it isn't leaking when they are doing the pressue testing, could it be leaking from the valve?? he did point out that the valve cover was missing, would it leak without the cover or could dirt stop it from working properly if some has got into the valve? If necessary can the valve be changed easily or is it a big job?
Any advice please
Any advice please
