I've got a 2010 2.0L diesel Sport and I'm trying to find the low pressure port so I can test the pressure of the air con myself. The high valve is easy to spot but does anybody know where the low one is?
I had the same issue, In the heat eventually found it hidden behind the EGR on the engine. Top right corner look behind it and its hidden behind there.
Locate the compressor, it'll have two pipes coming off it...
The high pressure is the smaller pipe, the low pressure in the larger diameter pipe.... then follow it along from the compressor til you find the check port.
