Technical Air con ECU problem
Alexis bs
Hi i got a problem with my 2005 Stilo JTD 115 dynamic, airn con doesnt start, can bus is ok but the ECU doesnt gives ground to the relay of compressor, i´ve checked the pressure sensor(at the beggining 1v, i force the compressor relay and 3 minutes later the pressure sensor show 5 volt) and all components or air con and all them are ok and it have gas ok, but in MES show 0,000bar pressure for compressor. when i try to activate thru MES the compressor relay says not ready to make the test. also when i try to do proxy gives an error on the clima module. i think the ECU doesnt catch the pressure sensor signal and thats why say not ready and the ac doenst work. Any idea? Thanks in advance!!
hanks guys but the pressure sensor i think works well i have tested on the ECU connector the signal, motor stopped 1volt, motor run and connect the compressor relay, pressure goes up and pressure sensor goes up to 5 volt. i dont know why the ECU doest catch the signal. maybe this volt are wrong? in MES it show 0,000 bar it would show some at least, i think. there is any way to check the ECU pin? is number 75. I mean to check if it is working or taking the signal or why MES show 0,000. there is any easy way to upload pictures??
