Afternoon from a Brava Driver with a problem
crewman135
Hi All,
I have a 2000 W reg Brava which I need help with.
I have an electronics problem, detailed on the general posts page, It is something to do with the services circuit and I keep loosing and dash display, indicators brake lights. Not ideal when driving a lot and at night!
I have swapped out the fuse which blew and the same thing happened again, By upping the rating on the fuse to 15amp or 20amp the problem does not seem to be an issue. This circuit obviously has some of the management systems on it as I cannot change from Park to any other gear without this circuit working.
There is also a smell of electrical smouldering but I cannot track this down very well so far, nothing seems to be out of place or shorting under the dash around the fuses there is nothing too hot or blackened anywhere that I can see.
If anyone has any suggestions as to what may have suddenly started to cause this problem please help.
