DanZ
This is going to be a long one so bare with me...
Hi all, I just purchased a Lanzar Dual amp wiring kit and it states that it comes with 17ft of 0AWG power wire, 3ft of 0AWG ground wire, 8ft of 4AWG power wire and 8ft of 4AWG ground wire...however...upon opening the kit it has the 0AWG stuff but instead of the 4AWG wires they are 8AWG!
It also states that it comes with:
1 in 4AWG and 4 out 8AWG grounding distribution block
1 in 0AWG and 2 out 4AWG ANL fuse block with 2 chrome 80AMP ANL fuses
But the distribution block is 1 in 0AWG and 2 out 4AWG or 3 out 8AWG!
Also the fuse block is 1 in 0AWG and 2 out 8AWG!!! (Surely this isn't right?)
The kit comes with a diagram to show you how to wire your system up and it shows 0AWG going into the fuse block and two 8AWG wires coming out of it (going to each amp obviously) but then it shows the grounding block with two 8AWG wires in and one 4AWG wire coming out, this can't be right can it???
I need someone clued up on audio to give me some advice on what to do here!!! Sorry for the long post.
DanZ
DanZ
