Technical Advance vacuum pipe
chesh
Established member
Can anyone please take a picture of where the pipe is connected from the carb side?
Ive changed the vacuum unit and it rips off every week.
Someone told me it might be connected to a different outlet and it sucks too much air when idle.
Can't see the carb as it's hidden under the airbox, but if it's the Weber 32 TLF, there are 3 vacuum ports on the back (top in your pic). Left most is the camcover breather, middle is the anti-stall and right (as per your pic) is the vacuum line for the delco.
Yes it is a weber 32tlf.
I am getting high vacuum from the pipe when it's connected to the carb even when idle.
A mechanic told me I should get a vacuum only at high rpm.
I've installed a new vacuum unit on the distributon and it failed after a week.
Could be a high vacuum problem?
