B boocar New member Joined Jan 31, 2009 Messages 19 Points 7 Location essex May 1, 2010 #1 hey folks my multipla handbrake now needs pulling up so high I catch my tops and rear-end when I get out of the car! How does hubby adjust the handbrake to it does not have to be pulled up so high. thank you
J joipalli Multipla Iceland Joined Jul 11, 2009 Messages 153 Points 35 Location Selfoss May 1, 2010 #2 If you take off the bottom cover of the handbrake lever. There is a screw there you can adjust by hand.
T taxiadam New member Joined Feb 5, 2009 Messages 59 Points 9 Location Birmingham Jul 11, 2010 #3 My handbrake now operates only when the lever is really high up so I need to make adjustments also. Do I let the handbrake off then adjust or should the handbrake be on and in it's highest position? Can I over tighten it or do damage? Cheers Taxi
BikeDoc Patron member Joined Oct 9, 2009 Messages 1,254 Points 305 Location South Bucks Jul 15, 2010 #4 Adjust with the handbrake off. Do it up until it comes on firmly after 3-4 clicks on the ratchet (don't hold the release button when you test it).
