Technical Adaption halogen to original full led or only drl in LED
Stevy
Belgium
Hello everyone,
At first nice to meet everybody.
I've just registered myself for this forum for the following.
I've a MH on a Fiat Ducato 2025 with the standard halogen lights also de DRL are in halogen.
Could someone let me know if it's possible to change the standard light to the original Fiat Full Led headlights and how to do this or change to tje drl in led and the others just in halogen?
Can these being programmed with for example the multiecuscan software or AlfaOBD, I've allready have the multiecuscan software?
Thanks for your help and kind regards.
Model
Ducato
Year
2025
Mileage
Welcome to the forum.
Depending on your headlight approval number, there might be EU street-legal LED bulbs for the headlight available from e.g. Osram or Philips for Belgium. I don't know if there are similar options for the DRL.
Hello MSjoberg, thanks for your answer. I have ordered original Fiat headlights with the DRL in LED, the other lights on in halogen. I hope that when I replace the complete headlight with the one I now have in halogen it is easy to adapt the computer of the Fiat so it can work with the headlight with DRL in LED. I've tried to exchange the headlights withour reprogramming but the computer gave an error about the lights and also when I turn the ignition on , the DRL in LED doesn't function. I've searched in this forum but can't exactly find how to reprogram this.
There is a solution in this thread:
The other option is to use AlfaOBD which has a parameter for DRL type under BCM adaptations and automates writing the new values to the proxy file.
Thanks and I'll try it, thanks for your help
@Stevy have you solved the issue? I was trying different coding, MES, AlfaOBD but no luck. Anyone can help?
Hello Gato,
I've just received the headlights with led DRL but u fortunately I haven't had the time to test it. I think I also need to buy the up to date MES software because mine is I think outdated. Gato, you've adapted the 2 values as mentioned above ? regards
Hello Gato,
I bought full led headlights, so after replacement halogen to full led they are working as designed without blinking etc. The only issue is bulb error on the dash. I tried different coding in bytes 76 and 134 in MES, in AlfaOBD switching DRL type, DRL diagnostics etc. No luck...
Hi Gato, did you find a solution in the meanwhile? Do you also have double speed turn light signal problem? Cheers, Buderus
