Technical ABS warning light
Nikky
The ABS warning light is currently on in my Schumacher Seicento, whats that all about:confused:
And how the hell dyou turn off the alarm ? The f*cking thing drains the battery because the car doesnt get used often.
rallycinq
Autotest Special
Lake District....Moist
If the car is not used often you could be getting a corrosion build up on a sensor wheel. You really need to find out which sensor is acting up, and the only way for that to happen is to get the code red.
Liam
hi friends :waves:
Scotland
Does it actually have an alarm? By that I mean an aftermarket one cos I don't think they ever came with one, your battery is maybe not the best in the first place so the not often ran just compounds the problem.
Do you have any added electrical gizmos plugged in somewhere?
If the car stays outside between uses then http://www.maplin.co.uk/module.aspx?ModuleNo=47902&doy=3m4&QV=P should help you out but only consider it if the battery is healthy and there is nothing draining the system elsewhere.
Liam
OP
OP
N
Nikky
At the time it started it was getting regular use, I think.
Theres no other cause ? whats it actualy for ?
OP
OP
N
Nikky
It does have an alarm and the battery had to go to a car electrical specialists to get a very fine charge and theres nothing else draining the battery
OP
OP
N
Nikky
The ABS light, is it supposed to be warning me its not working or........
AppleSei
RIP L181 VBB
West Yorks
could be an electrical problem, sensor playing up another suggestion, as been suggested i would take it for a code read/diagnostic in terms of the light, while youre getting that done ask them to check the brakes
I would purchase a new battery for the car and if its draining all power perhaps alternator could be on the way out, especially if cars not used much, consider contacting the manufacturer or previous owners of car and alarm if problem persists
Liam
hi friends :waves:
Scotland
The light would signify a fault in the system generally but only investigation will find the fault, could be one of many things.
Liam
