About alloy wheels PCD
Modena
Hello!
Do you know if wheels with 4x100 PCD will fit on cars with 4x98 PCD or not at all?
As far as I know most FIAT cars (including my Tempra) have 4x98 but many wheels can be found used with 4x100 so I need to know.
Thanks!
Hello!
Thanks!
Yes, you just use wobblies (A bolt with a collar on to take up the 2mm difference between the two).
As well as having the wheels with the correct offset and the correct spigot ring size (if needed) are used.
