retrogame888
- Joined
- Sep 25, 2010
- Messages
- 12
- Points
- 3
hi guys, need some help with this one, as not sure the gargage nows what they think they do.
i have 2 problems, well maybe 3.
the first and the worrie one, when my stilo abrth is cold, it smokes bad, not on tick over but when you rev it, or pull away at revs, the smoke looks like it is oil (blue) (grey) .. not black. it has no history with the car, and ive only had for a short while about 3 months. i havent done many miles since i have had it. and its done 32k. once it warms up, it is fine. the garge said suspect head gasket ?? im not so sure. its using no water, no oil/water contamination, they say its oil leaking in the exhaust ?? would a compresion test pick this up ?
i also had the oil presure low warning come up, and toped the oil up, as it was low. this has been ok since, the garage told me it needs a new oil pump, @ £800.. you guessed . i laughed, i after reading lots on here, i dont think the pump has gone, but any advice would be wecolmed,
the other is it has used a litre of oil in 500 miles, will it do this if its driven hard.
this weekend, i intend to change the oil filter and oil, air filter, just in case its over fueling as its nopt getting the right mixture, and probly change the gear box oil.
i have to get her sorted as she is so much fun
