Communicator
Prominent member
- Joined
- Aug 3, 2019
- Messages
- 1,986
- Points
- 533
I have mentioned my immobiliser problems previously somewhere on forum.
I had several instances of key code failure, but these had only happened while at home, with a cold engine, and not really needing to start the engine.
Last autumn I had a single failure when away from home with a warm engine. Started OK on immediate second attempt.
On checking earlier this year I had a 2 out of 5 or 40% failure rate. Confidence in the vehicle fell off a cliff.
I seriously considered buying and carrying a spare ECU with the code system deleted. However I reasoned that as the problem was marginal, it may be due to surface oxidation of the aerial connector contacts on the code receiver. The signal voltage will be very low at this point, and that there may be no contact
"wetting". (Wetting is a term used to describe the process whereby a higher DC voltage is applied to relay contacts, which would otherwise only have low signal voltages across them. Gold plated contacts used in electronic systems fulfill the same pupose.)
I was aware of some suggestions regarding unplugging and replacing the 8 way connector at the code receiver, but given the low signal levels, I thought the aerial connector to be a more likely cause.
Armed with a contact cleaner aerosol, I removed the steering column lower shroud, unplugged and treated the aerial connector, and while I was in there the 8 way connector which includes the data link to the ECU.
Subsequent testing has resulted in zero failures. Time will be the test, but worth a try if you are stuck with the padlock light on.
