General  A last resort - please help!
mark35at
Leoben
Have a Ulysse 2.0 EL 1995 Petrol. My tale of woe:
From cold start (starts no problem), between exactly 2000 and 3000 rpm, any gear, any speed - the car stutters very badly. About 10 minutes later when exactly 70 Deg. C is reached - fine no more problems. Driving above 3000 rpm solves the problem but I must use 1st gear to do that!!!
Have changed (the garage anyway) todate: pressure sensor, knocking sensor??,
lambda sensor, catalysator. A small fortune is gone.
CAN ANYONE HELP ME PLEASE?
I have had the problem of stuttering whilst drive before and my problem was fixed by discounting the ECU cleaning /spay wd40 then reconnecting. If you troll around the old threads you will find more info.
Good luck!
