EssexUno
- Joined
- Jan 20, 2009
- Messages
- 233
- Points
- 125
I finally got round to building and installing my punto 60 engine into my 1.0 Uno. I built it up includeing getting the pistons, crank and flywheel balanced i cludeing getting the crank pully fixed as the ruffwood key snapped off lol.
Got all the gaskets and bearings, new thermostat and water pump and also had to replace the front water pipe which you can only get genuine at £42 inc VAT :O
I'm still running the engine in and only covered about 160 miles since saturday night. Using 20w50 oil at the mo then going to change to either 5w40 or 10w40 semi-synthetic. There is soo much more torque than the 999cc unit and it pulls so much in fifth.
Anyone who is going to do this conversion, it is soo easy, had the old block out i. About 1 hour and the new engine took about 2hours to put in and grind a bit off the block to get the starter motor to fit.
I did this at my work so i was able to use a ramp and engine crane. I've got a 4-2-1 stainless supersprint manifold on which i had to modifiy to meed the Uno system. That took longer than getting the engine in lol.
I'll post some pics up soon because there on my phone at the mo.
Dan
Dan
