stuckinaffric
hi all :bang:,am wondering if anyone can help me out ,just got a ulysses 1.9 td s 1996,there is a keypad fitted on dash at drivers door when trying to tidy up vehicle i foolishly replaced the plug back into the rear of keypad,since then have not been able to start vehicle,i have tried removing the plug again but no joy,there was two 4 digit numbers on the manual,one of them i found out was the radio code,but i get no joy with the other number in the keypad i have tried both numbers,also the factory code of 1111,but still no joy,there are four wires coming out of the rear of the pump,which i take it are for a secondary fuel cutoff? the coluors are brown,yellow/red,black/brown,black.its a bosch pump fitted to the vehicle i would be forever in someones debt if they could help,i tried yahoo,one of the replies i got was to remove the shield at rear of pump where wires go in,with a grinder? then change solenoid inside with a non coded solenoid,does anyone know if you have to replace the shield after you have done this,i can find no ecu,aparently this model was fitted with a basic immoiliser ie not connected to an ecu,any help would be good as the wife is constantly giving me jip
,paid too much for the car,all estimates have been in the region of £200. cheers ian:worship:
