Hello folks just joined after trolling away in the background for a while and availing myself of the expertise and info on your fine site.
I've fallen heir to a 96 Punto 55 which I'm currently dismatling before the shell heads for the great breakers yard in the sky and I'm stuck for info on one bit.
I've tried to search for an answer on the forums and either the infos not here or I'm a complete berk and don't know how to work the system ( the latter being the more likely case ) so apologies if it's already been asked.
I've got the ECU out and have the matching keys. I've also removed all the locks barrels as they might be handy to go with the keys. I believe that the last thing I need to remove is the ignition barrel which will have the imobiliser thingy on it to complete the package. Is this so or is there some other thingy lurking about the dash that needs to come out too ?
Regards Rab
PS, 'Thingy' is a perfectly valid technical term down here !!
Regards Rab
