Since you ruled out cam timing and compression only three things needed, fuel, air and spark.
Fuel and Air: It starts so we know fuel is OK at idle. You say it looses power is this only under load or does the car rev OK when stationary ? Since you tried another carb and got the same results, did you set the other carb up the same giving the same issue or did you leave it the way it came ? If it is not the carb are you getting enough fuel pressure ?
Spark: You swaped the points and condensor but I would still not rule either out, I hav seen multiple bad ones before. Are the HT leads OK ? If you ground a spark plug to the engine for each cylinder are all 4 sparks good ? and lastly but best guess for the root cause of your issue would be the vaccum advance, is it working correctly when you rev the engine ? does the timing mark move when viewed with a strobe on the belt ?
Good Luck, don't give up. It worked once, therefore it can run again.
