Technical  903cc engine
Abild1312
Hi FiatForum,
I have a Fiat 127 903cc engine, that I want to update and hopefully also add a little power to in the end. First of all, is there anywhere on the engine itself you can se what type of engine it is or find a number that you can look up?
Second, what carburretors does fit this engine, if I for example want to upgrade it, can I then fit the larger Weber Carburretor from the sports models to my engine or does that require a huge rebuild?
I'm quite new in this, so I will probably need a dumbed down version of the explanation to understand it.. :D
Thanks in advance.
kind regards
Niels Abild
Hi fiatfurm I’m new I have this engine a112 903 cc bought use I would like to know what side of fuel pump push rod and what fuel pump I should put on thank you
