General  900e
General  900e
bighomer46
Hello, i am looking for the part no for the brake master cyl.
It is the double circuit.
If anyone has any information
Thank you in advance
David
Hi David
I replaced the master cylinder on my 900T last year, this had the front/rear split brake upgrade fitted (still drums all-around though).
There were no part numbers stamped on the unit that I was able to find. However, (as I found out) there are two types master cylinder for the split brake system. The difference between them is the fittings that connect to the brake fluid reservoir and the union threads for the brake pipes (my brake system now has a combination of unions M10x1.0 and M10x1.25 depending on what's connected).
It took a couple of attempts but I got the right combination through Ricambio (the image on their website didn't match what was in the box). The image on their website at https://www.ricambio.co.uk/brake-master-cylinder-fiat-900e for the 900e master cylinder is the one I have fitted.
Hope this helps.
