Help please guys!
I bought a 53 plate pet auto Ulysse.
I have had Ulysse/synergie/806 for the past 8 years now but this is my first venture into the new model.
Basically this car was to good a price to turn down.
I bought it with a 'gearbox' issue - supposedly with no gears after an ATF fluid change.
Obviously i did some reading on the matter first and was happy purchasing it.
that's the background out of the way!
I changed the fluid and low and behold got gears yipee!
However noticed i could only get reverse and occasionally drive.
Further investigation lead me to the gear selctor lever which has now been replaced.
Having replaced it I now get some wierd Sh*t* happening!
1. When i put the key in the ignition and turn on, the steering wheel display shows the 'snowflake' and 'up/down shifter' symbols and won't allow me to start the engine.
2. at the same time the green LCD display comes on but then goes off after about 10 and at the same time so does the snow flake/shiftersymbols on the steering wheel display.
3. the gear lever will not come out of the park position even with footbrake depressed.
Finally when i connect my OBDII up it will not even sync with the ecu (it did previously).
Has any had this issue before?
has anyone any ideas/suggestions?
many thanks.
many thanks.
