Hi
The combined MAP and Intake Air Temp sensor K044 pokes into the top of the inlet manifold with an O-ring seal, they have a tiny hole to communicate pressure to the sensor inside, and this is vulnerable to blockage from the oil/soot that always builds up over time in the intake manifold.
I don't normally advocate changing parts until they are proven guilty, but these sensors are only about £40 so it could be worth a gamble. Should be an easy swap (one connector, one bolt) but I don't know if you also have to take off the TB and/or its elbow pipe to get enough clearance.
It does seem odd that the old and new TBs are behaving differently though. What fault code are you getting ?
