bahamutzeta
- Joined
- Jul 7, 2014
- Messages
- 4
- Points
- 1
Hi all,
First post! I have an interesting issue with my 2012 Punto 1.2 8v..
Sometimes, when you need to give it a bit of whelly to make room at roundabouts etc, or to maintain proper distances between you and other cars / or need to boot it quickly (you get the idea) - I suffer from what can almost be described as an ECU lag at exactly 3500RPM in 1st gear only.
The engine forgets that full throttle is active, then 'wakes up' causing a nasty jolt forwards.
To experiment, I parked the car, put it into first gear, clutch still depressed, and revved the engine as hard as I could (I wanted to test full RPM range) - Yes the engine was hot.
The RPM would not go above 3500RPM.
Has someone fitted a form of launch control to my Punto lol? Can any experts out there explain what is going on with this little 1.2
Thanks for reading
Thanks for reading
