Technical 2017 2.3 130 / DPF differential pressure range
mikegolf
Gdansk
Hi, I have 2017 Ducato 2.3 (130 PS). I'm looking for an information what is a normal / correct range of DPF differential pressure readings, both on idle and under load.
I'm reading 12-14 mbar at idle, and up to 260-270 mbar at heavy load (accelerating on an uphill road, at about 3-3.5k RPM).
I'm looking for the reason of misbehaving turbo, it eventually reaches the target pressure but only at about 3k RPM. The system seems to be airtight, and the turbine itself has been checked at the regeneration shop, they claim it's good. This makes me wonder whether my DPF is clogged.
Year
2017
Hello @mikegolf
I’ve just watched this YouTube video of a 2017 Peugeot Boxer with EML on that turned out to be poor pressure sensor connections, but within that video live DPF pressure readings are shown which are not dissimilar to those @Googlebot has posted.
The same content provider has various Ducato/Boxer/Relay DPF problem solving videos that may be of use…
