Morning all, Ingot a 2012 Ducato 3.0 and can’t find the fault bringing on the eml light and airbag light.
eml
so basically do a code read and it come up with P053A PCV heater ‘A’ open circuit. I have done some hunting around and found an interesting video from the states explaining the this should be caused by a filter in the crank case, ordered one no change. I thought lets change the glow plugs as intermittently the glow plug light would flash, after having 3 snapped plugs got these replaced again no getter.
running out of ideas now anyone has this?
airbag
after the auxiliary belt snapped ever since the power steering light has stayed on along with the message check power steering, no visible damage to any loom or wiring, no codes, fluid level good and steering good anyone had this?
thanks guys in advance if you have any helpful comments.
eml
airbag
